Ninja Foodi dual zone Sync function for wings and roast potatoes, anyone use it much?
the airflow getting split thing isnt really a concern because each zone has its own fan. The wattage is shared so the max temp drops slightly when using both zones at once.
oh interesting, so if i ran both at 210 would they actually hit 210? or would they cap lower? has anyone tested with a thermometer?
I did. 200 for wings, 210 for potatoes. Sync. Each basket hit 195 and 203 respectively. So they do undershoot a bit. Single basket 2C of temp deviation from settings. Foodi is within 2C of set temp while oven usually 15C away so not a big deal.
thats actually really useful to know, cheers. So it does undershoot a bit when both baskets are in use at the same time but not enough to worry about. Did the wings crisp up properly at that temp?
Crisp as anything. 195 is fine, the convection fan does the trick. Just make sure to not overcrowd the basket and to pat the wings dry before adding to basket.
pat dry, baking powder dusting, single layer. Thats the holy trinity for air fryer wings
baking powder yes but have to make sure its aluminium free otherwise its metallic taste. Learned this the hard way with a batch of wings.
never used sync once with mine which ive had for 2 years. Use air fryer for potatoes for 15 mins then add in wings for the rest of the cook. If its a bigger meal just use oven. Its dual zone meaning you can cook two different things on two different days.
this is the correct take
