What does the E1 code on Aroma rice cookers actually point to?
Saw the E1 code come up a few times when people is troubleshooting Aroma rice cookers and decided to post what I've read about it. The E1 code indicate an open circuit in the temperature sensor. Essentaly the cooker cannot read any signal from the sensor so it cannot start up to heat the pots.
The suggestion is typically to open the machine up and inspect the sensor connection. Most of the time it isnt the sensor itself that is causing the issue, but instead one of the wires that is coming loose. If the sensor and connections check out, then you would have to replace the sensor itself.
Do the temperature sensor on these rice cookers use NTC thermistors as I seem to remember reading? Is it easy to find replacement?
yeah they're just standard NTC thermistors, usually 100k. I pulled one out of a dead ARC-150 last year and matched it to a generic off amazon for like 4 bucks. Nothing proprietary about it.
Open circuit on the sensor line is the textbook meaning of E1, so you're correct. Found this one three times... Twice it was a crimp connector that came loose at the base of the heating element, but once it was a cracked thermistor, visible crack in the sensor.
wait so if its 100k NTC does the resistance value matter for the machine or will it just read the curve of the thermistor and compensate?
dont bother fixing a cheap aroma, just buy a zojirushi and be done with it for 15 years
resistance value definitely matters, if you use a 10k instead of 100k it will think the rice is always cold and the element will run until something in the pot melt. Measure the one that's currently dead and get one that matches.
ok thanks for the info. If I can read the markings on the thermistor itself do I just trust those values or would they have to be measured?
Mine threw E1 and it was a strand of rice that had crusted onto the sensor pad. Just gave it a quick clean and it was good.
the rice crust thing isnt related to the E1 code though, that's more of a thermal sensing issue. It would have thrown an E2 or E3 code depending on the model. E1 specifically mean the controller sees infinite resistance on that line.
my cousin had his aroma rice cooker develop this issue and he just smacked the side of it with a rubber mallet and it worked for another 2 years lmao
If you can read the markings on the thermistor you can trust them. If not you can measure the resistance at 0C (ice water) and 100C (boiling water) and plug into a beta calculator, painful but doable. If it's a cheap rice cooker just identify the part number on the original thermistor.
the sensor on the arc-914 and arc-994 models are slightly differently in length but the sensors are otherwise identical.
Is the temp sensor the one stuck to the bottom of the inner pot well or is there a separate sensor in the lid?
Depends on the model. For the basic rice cookers there's only one sensor under the inner pot. For the rice cookers with keep warm and slow cook modes there's a sensor on the lid too.
on mine the wire has snapped but not the connection... It broke inside the heat shrink boot near the heating element. Once I re-soldered it it's been working fine for 8 months now.
one more dumb question. If the wire broke inside the heat shrink would it be ok to do the splice up near the heating element itself? would normal solder handle the temperatures near the heating element?
