lol my wife unplugged ours to vacuum and then asked me to reset it. Took me longer to find the manual than to actualy set the clock.
counterpoint, why does a coffee maker even need a clock. Just push the button when you want coffee. We're so deep into feature creep these days for appliances its insane.
does the auto brew time get wiped if you lose power to the machine? does it save that separately from the clock setting? if i set it to brew at 6am but then lose power to the coffee maker, would i have to reprogram the clock AND the auto brew time?
both get wiped. No battery backup for these machines. I looked into replacing the battery once when the clock was set to brew coffee but the power went out.
no battery backup on a $60 coffee maker. My $15 alarm clock from 1998 had a 9v battery backup. Priorities.
they cut every corner on these machines. They use the same pump in 5 different price range coffee makers. The clock circuit is made of a few cents of silicon that they could add a coin cell for $0.30 more but they dont. Its all margin.
my flexbrew clock died after about 4 years. Display doesnt show time but brews ok. Ive been using it without the clock for 2 years now and its fine.
that's just the display driver. Ive seen a few of these. Solder joint on the control board (if you wanna get in there with an iron) is bad.
would be the solder joints or the IC itself? if it were me im curious if its worth opening the machine up.
would be the solder joints. Ive fixed a few of these for friends. 2 of them involved resoldering the joints. The third was the IC and that one was a throw away.
this thread went from “how do i set the clock” to “lets desolder the control board real quick” lmao
