What strength setting are you guys using for their espresso recipe? I'm currently on the middle bar but I'm concerned that my shot will be watery.
two bars (second lowest). Plenty strong with a decent bean.
The double dose is not twice the strength of singles because the machine does not fully reset the dosing timer between singles. At least that’s what a Delonghi tech told me when I had my machine in for service.
wait so does that mean if I make two singles back to back will it under dose compared to making two singles separately?
lmao at this whole thread discussing dosing in grams when the Magnifica cannot properly tamp 15 grams of ground coffee. You're optimizing for a fundamentally limited machine.
clean. The. Grinder.
How often should the grinder actually be cleaned though?
To actually answer the question posed by the OP. The grind size and cleaning of the machine is what will fix the problem (permanently) versus the strength setting of the espresso machine. The strength setting will work but it will not fix the issue if the grinder is gummed up. Ge…
