Magnifica grinding way too much coffee per shot, common cause?
The double dose is not twice the strength of singles because the machine does not fully reset the dosing timer between singles. At least that’s what a Delonghi tech told me when I had my machine in for service.
wait so does that mean if I make two singles back to back will it under dose compared to making two singles separately?
wait so its the bean hopper? yes its real. Mine had a gap in the rubber but beans fell in too fast. Once I fixed it with a tiny bit of food safe silicone the dose dropped by like 3 grams
lmao at this whole thread discussing dosing in grams when the Magnifica cannot properly tamp 15 grams of ground coffee. You're optimizing for a fundamentally limited machine.
sure but its the machine people have. Not everyone wants to drop 2k on a lever.
To actually answer the question posed by the OP. The grind size and cleaning of the machine is what will fix the problem (permanently) versus the strength setting of the espresso machine. The strength setting will work but it will not fix the issue if the grinder is gummed up. Get the grinder changed and cleaned first. Then play with the strength setting as fine tuning for taste.
i just use the coffee button on my machine instead of the espresso button. It hasnt failed me yet for 3 years atleast. Its probably wrong but however you do it its working for me.
To actually answer the question posed by the OP. The grind size and cleaning of the machine is what will fix the problem (permanently) versus the strength setting of the espresso machine. The strength setting will work but it will not fix the issue if the grinder is gummed up. Ge…
so the time of the motor and the throughput of the beans will mostly control the dose? the grind size will control the throughput of the beans, the strength will control the time of the motor and the machine senses that the grinder hasnt gummed up when the coffee is brewed?
