Assault Air Rower Elite, damper setting and form tips for new users?
After several months of operation, you might find your machine squeaking. That's when you'll want to check the seat rollers, as that's usually where the squeak comes from. Clean your chain according to the owner's manual, but if the problem continues after that, it is time for an…
If your machine is squeaking, check the seat rollers rather than the chain. On these models, that's typically where the noise comes from as they can collect dust and their bearings dry out over time.
Turns out, it was just a squeak in the seat rollers. Look there now and clean/lube them up as necessary.
You have a studio and reside on the second floor of an apartment. The concern here: how noisy is the Elite? When selecting home gym equipment, sound transfer to your downstairs neighbor is a major consideration.
An air rower will always be noisy because of the fan. This isn’t necessarily a bad thing, but just something to know about if you live in a downstairs apartment, for example. There's no way to drown out the noise of an air rower without affecting the resistance (and thus the effectiveness) of the machine. A magnetic rower would work better for that.
You know what I mean? You are gripping too hard and burning up your forearms. This continues until someone tells you to relax your grip, and then you'll be able to row farther without your hands getting all cramped up. Feels counter intuitive as hell, you're afraid of letting go of the handle, but with that hook grip you've got plenty of security for pulling as hard as you want.
You know what I mean? You are gripping too hard and burning up your forearms. This continues until someone tells you to relax your grip, and then you'll be able to row farther without your hands getting all cramped up. Feels counter intuitive as hell, you're afraid of letting go …
It’s a reminder that form makes a huge difference in how the exercise feels on your body, and this story proves it.
The other thing that gets overlooked is catch position. Keep your back angled forward from the hips but keep it flat (not rounded). Don't let your legs get behind you, they should be vertical or slightly in front of vertical. Keep your arms straight. No matter what damper setting you have, if your catch position is wrong, every stroke will be inefficient. Most people’s catch positions appear to be incorrect when filmed from the side.
The other thing that gets overlooked is catch position. Keep your back angled forward from the hips but keep it flat (not rounded). Don't let your legs get behind you, they should be vertical or slightly in front of vertical. Keep your arms straight. No matter what damper setting…
One of the greatest things you can do to help your form is film yourself. I thought my technique was good for years, but then I got on camera and saw that I was opening up my back way too soon. That's all it takes to lose 15 seconds off your 2k time. Not sexy advice, but good if you want to make incremental changes and see results.
So you're wondering, is this just some sort of marketing scheme? Is the Elite a more worthy purchase for that extra money over the standard Assault rower or not? The Elite is mostly marketing; it has a slightly beefier frame and a better seat, but the flywheel and mechanics are basically identical to the regular Assault rower.
So you're wondering, is this just some sort of marketing scheme? Is the Elite a more worthy purchase for that extra money over the standard Assault rower or not? The Elite is mostly marketing; it has a slightly beefier frame and a better seat, but the flywheel and mechanics are b…
For the most part, it's a marketing upgrade. It has a little heavier duty frame and a slightly improved seat, but other than that, the mechanicals and even the flywheel are basicly exactly the same as the regular version.
The suggested alternative to buying a Concept2 is usually less expensive and will perform just as well, if not better, at the same price point.
I’ve seen this recommendation made in nearly all of the forum threads. And to be honest, it can feel a bit preachy and redundant for certain people.
