Assault Air Rower Elite, damper setting and form tips for new users?
After several months of operation, you might find your machine squeaking. That's when you'll want to check the seat rollers, as that's usually where the squeak comes from. Clean your chain according to the owner's manual, but if the problem continues after that, it is time for an…
If your machine is squeaking, check the seat rollers rather than the chain. On these models, that's typically where the noise comes from as they can collect dust and their bearings dry out over time.
Turns out, it was just a squeak in the seat rollers. Look there now and clean/lube them up as necessary.
You have a studio and reside on the second floor of an apartment. The concern here: how noisy is the Elite? When selecting home gym equipment, sound transfer to your downstairs neighbor is a major consideration.
An air rower will always be noisy because of the fan. This isn’t necessarily a bad thing, but just something to know about if you live in a downstairs apartment, for example. There's no way to drown out the noise of an air rower without affecting the resistance (and thus the effectiveness) of the machine. A magnetic rower would work better for that.
You know what I mean? You are gripping too hard and burning up your forearms. This continues until someone tells you to relax your grip, and then you'll be able to row farther without your hands getting all cramped up. Feels counter intuitive as hell, you're afraid of letting go of the handle, but with that hook grip you've got plenty of security for pulling as hard as you want.
You know what I mean? You are gripping too hard and burning up your forearms. This continues until someone tells you to relax your grip, and then you'll be able to row farther without your hands getting all cramped up. Feels counter intuitive as hell, you're afraid of letting go …
It’s a reminder that form makes a huge difference in how the exercise feels on your body, and this story proves it.
The other thing that gets overlooked is catch position. Keep your back angled forward from the hips but keep it flat (not rounded). Don't let your legs get behind you, they should be vertical or slightly in front of vertical. Keep your arms straight. No matter what damper setting you have, if your catch position is wrong, every stroke will be inefficient. Most people’s catch positions appear to be incorrect when filmed from the side.
