Running just one basket on the Ninja Foodi dual zone, what's the actual sequence?
Worth noting that the FlexDrawer model has a different button sequence because it comes with a removable divider that allows you to use the machine as one giant air fryer. Instead of using 1 or 2 you use the MegaZone button. The rest of the functions are the same though.
mine does the same thing on zone 2, i think its just because of how the fan motors arent the same from the factory. I would leave it alone unless its getting worse over time though.
oh thats actually cool i didnt know about the megazone thing. So with the FlexDrawer model if you remove the divider can you only use the air fryer in single small zone mode or does it allow for both modes?
You can do either. If the divider is in the machine it will limit the appliance to zone 1 and 2 but if you remove the divider it will allow it to go into megazone mode. There’s a little sensor on the machine that detects the position of the divider.
