Quick reference for what the BlendJet light colors actually mean
see other threads discussing this issue, someone commented that blue means battery is fine. Flashing red means the jar are not correctly aligned with the blades. Solid red indicates the blade is stuck. Flashing purple means its in lock mode (kid mode?), spinning purple means battery is getting low. Flashing red and purple means battery is completely flat. So purple relates to the battery and red relate to the machine itself.
Why re-use red for two different thing? This is amateur hour. You would think for any equipment out there, you would get a specific code for a specific fault. This is a toy though so whatever.
