Ninja Blast charging issue, anyone swapped the 18650 pack?
spot welder is overkill for this. Pre-tabbed 18650 cells can be had on aliexpress for around 8 bucks shipped so just solder the tabs on the cells rather than the can.
pre-tabbed cells are fine but the tabs that come pre-welded to the cells are usually thin garbage steel that is just nickel plated. For blending application proper pure nickel strip is preferred.
opened mine up last month. Confirmed bms is on the same board as the usb port and the cells are held in a plastic cradle with double sided tape. Comes apart with a spudger going around the seam. Four plastic clips to pop, no screws on this model.
no screws? did you break one of the clips?
i work on ebike battery packs for a living so seeing people take the time to do this is wild lmao. Respect to the people that put in the time and effort. The same principles are used but for a smaller scale application. Proper cell matching, nickel strip, spot weld, decent bms. If people treated these pack like e-bike packs they’d last years. Never solder to the 18650 can with heat otherwise it damages the seal and you get a leaky battery.
i work on ebike battery packs for a living so seeing people take the time to do this is wild lmao. Respect to the people that put in the time and effort. The same principles are used but for a smaller scale application. Proper cell matching, nickel strip, spot weld, decent bms. I…
what spot welder do you use for these little thing? full kweld is overkill for this.
sunkko 709a is my go to for these smaller 18650 cells. It does.1mm.15mm nickel strips which is enough for these but wouldn’t be trusted with a larger battery pack.
for ninja blast blender specifically the charge port is where people should start, the most common cause. Use a multimeter to test the input voltage on the charge port. Then go into the blender. Only if the port is fine will the battery be the issue.
this is what i was sayin earlier. Its the charging port like 90% of the time
if its just a cracked solder joint on the usb port can you reflow that without taking the battery pack apart? does the bms come with the battery pack?
yes it can be reflowed in place. Battery pack doesn’t need to come apart the board just needs to be opened enough to get to the usb ports. Takes five minutes to do with a hot air station.
