Cooking lentils in an Aroma rice cooker, does the white rice setting actually work?
A few peoples have mentioned using an Aroma cooker for lentils instead of rice. It seem simple enough if it works. From what I can find, the ratio is 1 cup lentil to 2.5 cups of water, rinse the lentils and run the white rice program for 50 minutes which should be more same as boiling the lentils on the stove.
The question is, does the white rice program allow the lentils to fully cook through? I would think not because rice cookers will shut off based on temperature rather than a timer once the rice has absorbed the water. Thus the 2.5 cup ratio of water would be main factor in allowing the lentils to cook through.
I would think that this would work best with the smaller lentils such as red lentils or split lentils. I found this very annoying that an article did not specify the variety of lentil as to what type was used. Have any of you tried cooking lentils in Aroma cooker using the white rice setting? Did you have to run it twice to cook the lentils through?
cooking-lentils-in-an-aroma-rice-cooker-does-the-white-rice-setting-actually-work-1.jpg
cooking-lentils-in-an-aroma-rice-cooker-does-the-white-rice-setting-actually-work-2.jpg
cooking-lentils-in-an-aroma-rice-cooker-does-the-white-rice-setting-actually-work-3.jpg
cooking-lentils-in-an-aroma-rice-cooker-does-the-white-rice-setting-actually-work-4.jpg
cooking-lentils-in-an-aroma-rice-cooker-does-the-white-rice-setting-actually-work-5.jpg
cooking-lentils-in-an-aroma-rice-cooker-does-the-white-rice-setting-actually-work-6.jpg
cooking-lentils-in-an-aroma-rice-cooker-does-the-white-rice-setting-actually-work-7.jpg
cooking-lentils-in-an-aroma-rice-cooker-does-the-white-rice-setting-actually-work-8.jpg
cooking-lentils-in-an-aroma-rice-cooker-does-the-white-rice-setting-actually-work-9.jpg
Just ran a cup of red split lentils with 2.5 cups of water in an 8 cup Aroma cooker and it took roughly 50 minutes to soften into a dal like consistency. No second cycle needed though I let it sit on keep warm for 15 minutes. A little too mushy though if thats what youre after.
The premise of the article is a little off. The rice cooker will shut off on temperature though the white rice setting on the Aroma cooker does go through a phase where it warm the rice and lentils before it boils the contents which accounts for the 50 minutes of cooking time.
So when you run lentils through it you get 10 min warmup to absorption at a low temp and then it goes to a boil to absorption and then it kicks it to warm to keep them warm. For red lentils that’s plenty. For anything bigger its not enough heat.
So…
so if i did black beluga lentils would i need to soak them overnight first or could i just bump the water to like 3:1 and run two cycles?
the aroma is like a 25 dollar appliance with no sophisticated algorithms for cooking lentils. Its just a thermostat and a heating coil. As long as theres water in there its going to boil. Once its gone its going to spike to click. Its just a 2.5:1 ratio works for red lentils because of the absorption time
I tried this with French Green (Puy) and after one cycle they were undercooked. Second cycle (with splash more water) after an hour and 40 min they were good though.
simply because the description did not specify the type of lentil because the author of this recipe likely only ever used red lentils and assumed everyone know lentil is lentil.
