See the fun question about the pre-ground coffee funnel on the De'Longhi Magnifica machine getting gunked up? Thought it was worth a discussion.
According to the manual and some older posts, the recommendation is to brush the funnel out, vacuum it to remove the stuck ground, and then the user should pull the infuser out to clean that as well. This is because the funnel dump directly into the infuser. People sometimes forget to clean the infuser though, only cleaning the funnel by poking at it from the top.
What steps do people take for their Magnifica machines beyond the brush and vacuum routine? People can clean the funnel according to a set schedule to remove any coffee grounds that may have gotten into the machine that dont get used in the pre-ground coffee compartment all that often. However, from what I’ve seen most people do is just the routine laid out in the manual. Does anyone here actualy utilize a different approach to cleaning these machines?
