Anyone got tips on setting up the Hoist ab machine properly?
This is how to set up the Hoist Fitness abdominals machine. According to general agreement regarding the Hoist Fitness abdominals machine, the main concerns involves safety, resistance selection, range of motion, and posture. I found a short guide that addressed those topics; it shows that most people just plop down into the machine, attach some weight, and go to town without bothering with any adjustments. Basically, you want to choose the right amount of resistance by targeting your abs instead of using momentum or your hip flexors. You also need to use the pads to brace your back and allow the movement to happen over the full range while controlling it. Although adjusting your posture seems to be skipped, this step is important for the same reason why you use an isolation machine, specifically to target isolated muscle groups. Without proper pad and seat placement, there’s no isolation benefit. Those who train regularly with the Hoist ab units might have their own favorite way of setting up the machine. Instructions advise doing it light at first so you are working more on contracting your muscles than fighting against resistance. Also, you don't want to use too much momentum or incorrect setup with weight, as that could be dangerous for the lower back. Before starting, a normal adjustment routine will help in getting your form right.
The trick is to have your seat height set such that you roughly hit the middle of your stomach (belly button) at the pivot point. Anything less and it won’t work as well because your abs aren’t contracting; rather, you’re pulling on your hip flexors. Within a day or two you’ll feel some back pain.
You should start out with a lighter weight. You’ll see some people load it all up and just rock back and forth without really using any of their abs. When used properly, hoist units is very well designed because you get resistance from the cam throughout the entire range of motion.
When using the Hoist CL series, you want your pivot to be aligned with your lower ribs (or slightly higher above your belly button), as opposed to being in-line with your sternum. When this is so, the crunch starts up too high and it’s more of a compression of the chest rather than an abdominal contraction.
When using the Hoist CL series, you want your pivot to be aligned with your lower ribs (or slightly higher above your belly button), as opposed to being in-line with your sternum. When this is so, the crunch starts up too high and it’s more of a compression of the chest rather th…
The height is also something to adjust if you're tall. If you're on the taller side, like 6'3" then maybe these machines are made for an average body size.
These machines are oversold as isolating the abs to a perfect degree. Your abdominals will be better developed with heavy compound movements and hanging leg raises. If you choose to work on them using the machine, do full reps, not partials.
There is also a category of individuals who like the ab wheel better than machines. One user argued that you get better ab development from heavy compounds and hanging leg raises than any machine.
Free-weights exercise and machines aren’t at odds with each other. For example, the Hoist unit offers a controlled range of motion during loaded spinal flexion that’s hard to get through bodyweight only. Each has its use in a training plan.
What I've noticed is people don't really change their settings. I saw one person fold them up in half, without any muscle power, just with momentum (that's a lot of force on your lower back). And another guy used it at a very low pin setting.
While some Planet Fitness centers has installed the Hoists, it’s not a universal fixture at every gym. These are usually found in their larger gyms.
"Older ones tend to seize up," he says of the seat pin. So you need to check whether it's moving freely before exercise. Once the seat is properly in place and your navel is lined up with axis, set the range limiter to avoid stretching too far at full extension if your machine has one. Perform a warmup set with 25% of your working weight to get form right. If your abs fail to engage and your hip flexors take over, correct this by dropping the seat an inch or two. It lasts about 45 seconds, but many will do without it.
"Older ones tend to seize up," he says of the seat pin. So you need to check whether it's moving freely before exercise. Once the seat is properly in place and your navel is lined up with axis, set the range limiter to avoid stretching too far at full extension if your machine ha…
The range limiter caps how far back the machine extends during the eccentric so you don't hyperextend your lumbar spine at the top of the rep. It's great if you have any problems with low-back.
Focusing on peak contraction is good advice. It lets you focus on the moment the muscle is contracting the most, allowing you to hold that squeeze for a second while still controlling your downward motion. This means focusing on the squeeze at contraction rather than chasing plates.
Focusing on peak contraction is good advice. It lets you focus on the moment the muscle is contracting the most, allowing you to hold that squeeze for a second while still controlling your downward motion. This means focusing on the squeeze at contraction rather than chasing plat…
Most people do not really contract their muscles, but rather simply bounce up out of the bottom position and give little or no attention to the peak contraction.
For some people, this is just another weighted crunch. But there’s more to it than that, it provides progressive resistance and a fixed axis of rotation, both which make for a large change in comparison to traditional crunches. Careful attention should of be paid to how you load your spine during setup.
