Anyone got tips on setting up the Hoist ab machine properly?
This is how to set up the Hoist Fitness abdominals machine. According to general agreement regarding the Hoist Fitness abdominals machine, the main concerns involves safety, resistance selection, range of motion, and posture. I found a short guide that addressed those topics; it shows that most people just plop down into the machine, attach some weight, and go to town without bothering with any adjustments. Basically, you want to choose the right amount of resistance by targeting your abs instead of using momentum or your hip flexors. You also need to use the pads to brace your back and allow the movement to happen over the full range while controlling it. Although adjusting your posture seems to be skipped, this step is important for the same reason why you use an isolation machine, specifically to target isolated muscle groups. Without proper pad and seat placement, there’s no isolation benefit. Those who train regularly with the Hoist ab units might have their own favorite way of setting up the machine. Instructions advise doing it light at first so you are working more on contracting your muscles than fighting against resistance. Also, you don't want to use too much momentum or incorrect setup with weight, as that could be dangerous for the lower back. Before starting, a normal adjustment routine will help in getting your form right.
