Heads up before anyone factory resets a Home Hub over this.
HA 2026.10.1 started showing this on hubs the Reolink app lists as Local:
Firmware 3.3.0.601 makes the hub advertise the newer v3 login and reolink_aio reads that alone as account device. 2026.10.0 still works. Fix is sitting in the library, so a reset probably changes nothing.
The Reolink device is set up as an 'account device', which blocks local login. Reset the device and set it up again as a 'local device' following the Reolink instructions:
