heads up for anyone syncing to filen with rclone. if a folder on ur side is Photos and on filen its photos (only the case differs), sync uploads the file again, filen keeps the old one as a version, then the delete step dies with
and it does the same thing every run, nothing ever gets cleaned up. matching the folder case on both sides should stop it. anyone tried --fix-case on filen tho
Couldn't delete: response error: This file is versioned. file_is_versioned
