Instant Pot burn message what actually triggers it?
thick sauce trick: start with water on the bottom of the pot (a full cup), then add in your protein of choice and finally the thick sauce/liquid that floats on top of the protein. Do NOT stir. When its cooked simply stir it all together at the end.
sounds like alot of work to avoid an error message tbh
the layering trick actually works but people also tend to forget about the sugar content in jar sauces. Sugar tends to char/scorch in the pot MUCH faster than homemade sauces. Check the label to see if it contains sugar (should be near the top of ingredients listed).
yes! sugar is a big factor people miss. Bbq sauce is the worst for this, chars to the bottom in 30 seconds at those temps.
must deglaze with a wooden spoon after sautéing the protein. If its stuck to the pot, scrape with spoon until smooth. Takes 20 seconds but saves the rest of the cooking.
Worth noting that if the ingredients are cold and straight from the fridge and placed into the hot pot, the burner will flash error: burn. This is due to the difference in temperatures between the cold ingredients and the hot pot. Allow ingredients to reach room temperature or sauté prior to cooking.
my MIL just dumps everything into the pot raw, adds the can of tomatoes and sets it for 30 minutes. Never has a burn error. I follow the recipe to the letter and get burn error every other time I cook. I think the machines just hate me personally.
Worth noting that if the ingredients are cold and straight from the fridge and placed into the hot pot, the burner will flash error: burn. This is due to the difference in temperatures between the cold ingredients and the hot pot. Allow ingredients to reach room temperature or sa…
check your ring. Seriously. Make sure it’s not seated in the pot correctly. There’s a little tab that should line up with the pot. Might be your problem.
also check the seal of the float valve (silicone bit on underside of lid). If its gunked up and not making good seal, you’ll lose the pressure in the pot and the pot will dry out before the cooking cycle is over.
