How accurate is the built-in pulse sensor on NordicTrack treadmills?
What do you all think of the heart rate grips on NordicTrack treadmills?
Place both hands on the metal grips and the treadmill will take a reading of your heart rate from your palms. Standard feature on treadmills in this price range.
According to a write up, the treadmills heart rate sensor compares with Apple Watch heart rate sensors at the same time and displays very similar reading.
Generally, grip based sensors are only approximate. The same can be said for optical sensors taking heart rate measurements from the wrist.
For casual use, NordicTrack treadmills heart rate grips is fine. For training zones, a chest strap sensor will beat the treadmills heart rate sensors. For individuals looking for an approximate reading without purchasing a chest strap sensor, the built in heart rate sensor from the treadmills is usable. Have you compared the heart rate sensor from your NordicTrack treadmill with the chest strap sensor?
chest strap or it didnt happen. Grip sensors are a gimmick at best, ive never had one read within 10bpm of my polar h10
I’ve tested the heart rate sensor on my 1750 treadmill against a Wahoo Tickr sensor. The readings are within 3-5 bpm when resting or doing low intensity intervals. When I hit 140 bpm or above and my hands starts to sweat, the grip sensor essentially fails. It will show either 90 or 180 when I know my bpm is somewhere in the high 160s. It’s fine for warmups though.
why does sweat mess it up though? wouldnt more moisture mean better contact with the metal?
The sweat introduces salt to the measurement and also likely messes with the sensors grip pressure when gripping with sweaty palms. The sensor measures the voltage in each hand and anything that mess with that reading is going to cause incorrect bpm measurements.
ok that makes sense. So is it actually ECG based then? i thought it was optical like the watches
Had a NordicTrack X22i for 3 years. The grip sensors were fine but I found that holding the handles in the proper position for reading my heart rate messed up my running form. I switched to a Scosche armband sensor and haven’t look back.
scosche rhythm is legit, agreed. Forearm optical sensors seem to be the most accurate out there for measuring heart rate
Question for the chest strap evangelists in here, has anyone tried the heart rate grip sensors on a treadmill with dry hands vs. Wet hands? Does lotion help with the grip sensors?
my commercial 2950 heart rate grip sensor measures my heart rate but also measures my wifes heart rate when she steps on it so it definately works lol
I feel the quality of NordicTrack treadmills has declined so much in the last 5 years. I had to replace the deck on my X22i after 8 months due to warpage from lack of quality control.
for casual use, yes. Grip sensors on treadmills can mess with proper running form. People have to hold their hands in an awkward position so the grip sensor can measure their heart rate.
fwiw, i tested the grip sensor against my polar h10 and fenix smart watches. At low intensity, the grip sensor was within 5 bpm of my h10 and fenix. Once i started to sweat, the grip sensor went haywire. It’s inaccurate when the measurement is compromise.
sound like a lot of work to find out something we already knew prior to this treadmills existence
