See some posts on the FlexBrew units that won’t push water through anymore, hence the topic of discussion about this issue. There are 5 usual suspect for these models before people give up on the machine.
The first is that the reservoir is low on water. After that it could be a clogged water tube (flush it). Beyond that the actual pump could be failing (bad repair). The other two are user error related; the latch on the brew basket could be an issue or the water tank latch doesnt seat proper into the machine; or the holes on the FlexBrew reservoir could be plugged on the carafe or the single serve side of the machine.
What is the most likely of the 5 suspects? I’d say scale in the machine or clogs in the holes since these machines sits with water in them and nobody descales them. But have you done any repairs on a few of these models to see which of the 5 is the most common?
