Hamilton Beach FlexBrew dead, no power at all, what usually causes it?
A few folks has been asking me about FlexBrew units that just go dark. No lights. No response on the panel. Nothing. These dont have fuse inside them, so no easy fuse to replace.
From what I see, there are three general cause. The first is a software glitch. The fix is to unplug the unit for 5 to 10 minute and then plug it back in. This usually fix the problem for a chunk of the FlexBrew units that have software glitches. The second is that the electrical component on the control board have failed. You have to open the unit up and look for signs of this. The third is that the display panel itself has failed. The ribbon cable to the control panel has worked loose and the unit is dead, but the control board itself is fine. Just reseat the panel.
Given these three causes, which is the more common?
The reset is the easiest fix, but the most common cause are the display panel.
The display panel failure is way more common than people thinks. I've opened up 5 or 6 of these for friends and family and 3 of them had the ribbon cable to the display panel that was back out a little bit. Replacing it fixed the problem. The control board failures were due to power surge or people using a sketchy power outlet.
Hamilton Beach use pretty cheap connectors so they walk loose over time from the thermal cycling.
the 5-10 min unplug thing actually worked on mine last year, thought i was gonna have to toss it
wait why does unplugging it for that long even do anything? like is there a cap hold state or is it a firmware watchdog thing? 10 min seems oddly specific
Honestly for what these cost new I wouldnt spend more than 15 minute troubleshooting one. Lifes too short to be reseating ribbon cable on a $60 coffee maker.
there's usually a bulk cap on the low voltage side that holds charge for a while, and some of the micros needs a full power down cycle to clear a latched fault state. 10 min is overkill but it guarantees the cap fully bleed down. You could probably get away with 2-3 minutes honestly
Disagree with the take that connector is underrated. In my experiance the triac on the control board is what die most often on these, especially on the dual brew models where the heater pulls hard current through it. Look for a small black component near the relay, if it's discolored or smells burnt thats your culprit. Loose ribbon is a thing but it's like maybe 1 in 5 of the dead unit I've seen, not the majority.
