Frothing milk on the De'Longhi Magnifica, wand position question
Was taking a look at the notes on the steam wand of the Magnifica. Thought it would be good to share what I found since the topic come up alot. The position of the steam wand effect the type of steam you get out of the machine. If you raise the steam wand above the spout you get hot milk as opposed to lowered steam wand for cappuccinos. I didn’t think about it that much before but apparently thats the trick to it.
The rest of the routine is somewhat standard. Press the steam button and wait for the ready light to come on. Fill the jug to the one third mark with milk (expands when frothing). Once ready turn the knob to the froth setting.
Now the question is what do you all think about the raised lowered steam wand debate? Does it actualy matter that much? Do you have to wait past the ready light once it comes on? From what I understand the ready light is a little deceptive on these models as it comes on before the machine is truly ready. Anyone have experiences with the Magnifica that may shed some light on this?
the ready light is a liar on these machines. I always wait a solid 30-45 seconds past it before actually opening the steam valve, otherwise you get that wet sputtery start and it ruins the foam texture from the jump.
Wand up vs down does matter but honestly not as much as people make it sound. Jug angle and how deep you hold the tip is doing 80% of the work imo.
wait does the raised wand actually disable the air intake or does it just reduce it? i always assumed there was a little hole somewhere that got covered
Frothing on a Magnifica is like trying to do brain surgery with a butter knife. Get a real wand or accept that its always going to be mediocre.
the panarello attachment thing has a sleeve that slides up and down. When its down it pulls air through a side hole, when its up it covers the hole so you just get steam. Its not a fancy mechanism just a sliding tube basically.
i mean technique matters but you cant technique your way past a clogged panarello. Clean that thing every single time or you'll be wondering why your foam went to crap in 3 weeks
oh interesting so its literally just a venturi effect with a manual cover. Thats actually kinda clever for how cheap it is. Does the hole clog easy with milk residue?
Had my Magnifica S for 4 years now and I'll tell you exactly what works. Wand down, milk straight from fridge (cold milk has more time to stretch), jug tilted about 20 degrees, tip just under the surface until you hear that paper tearing sound, then plunge it deeper to roll the milk once you've got the volume you want. Stop at 60-65C, you can feel it on the side of the jug when it's too hot to hold for more than a second. Ready light I treat as a 'start counting to 30' signal not a go signal. The boiler on these is tiny so the thermostat trips early.
Also wipe the wand IMMEDIATELY after, dont let milk dry on the panarello or you're rebuilding it with a toothpick in 2 weeks.
yes it clogs constantly if you dont purge steam through it after each use and wipe it down. The hole is tiny like 1mm.
Had my Magnifica S for 4 years now and I'll tell you exactly what works. Wand down, milk straight from fridge (cold milk has more time to stretch), jug tilted about 20 degrees, tip just under the surface until you hear that paper tearing sound, then plunge it deeper to roll the m…
60-65C is the sweet spot yeah. People scald their milk and wonder why it tastes like cardboard.
4 years and you're still defending the panarello lmao. Ok
another question, if i pull the panarello sleeve off entirely can i steam milk with just the bare wand for proper microfoam? or is the steam pressure too weak without the venturi assist?
you can but the pressure is too weak on these to do real microfoam. Its a single boiler with a tiny thermoblock basically. You'll spend 90 seconds stretching milk that should take 20.
