Float samples must be 32 or 64 bit popup and double commander just sits there
11
what is a 16 bit float even doing in a file manager. double commander 1.2.10 on macos 27 dies before any window shows up, Ok does nothing, alpha snapshot works apparently
Float samples must be 32 or 64 bit, but found 16 at position 18632.
Press OK to ignore and risk data corruption.
Press Abort to kill the program.
Closed as fixed by the dev. Grab the 1.2.11 snapshot (r414 or newer), there are arm and intel dmgs. Or just roll back to 1.2.9, that one still opens on 27 without the error.
