is there a way to add an inline temperature sensor that will allow me to monitor the coffee machine’s boiler prior to the failure of the fuse?
Regarding the causes of blown fuses here's what I've found in my 15+ coffee machines: 90% are due to scale in the boiler from using hard water that hasn't been descaled in a while. 5% of the time the machine ran dry and the thermal fuse on the heater is meant to act as a safety c…
do I have to remove the boiler to access the fuses or can I do it with the machine still mounted to the machine?
The generic fuse will work just as well but ensure that the temperature is correct and that the fuse is rated for at least 10 amps. A 5 amp fuse will blow in less than a day on some machines because the heater draws more current than that.
meanwhile my 1995 gaggia is still chugging along with the original everything.
if my machine isnt getting heat I start with the fuses and work my way through the thermostat, then the triac and finally the element itself. Is that the order in which these components are supposed to be checked?
Regarding descaling: most DeLonghi coffee machines have an aluminum boiler where the scale readily sets. When the scale forms it prevents the heater from properly transferring heat to the water which then causes it to overheat and pop the fuse. People ignore the descaling light o…
my descaling light has been on for like 8 months now. Should I be worried that it's time for me to descale?
do citric acid descaling solution work or vinegar so it's less expensive than the official coffee machine solution?
