This is a common problems, inactivity cause the DeLonghi machine to stop pumping water. Simply turning the machine on and off a few times will resolve this problem. It sound dumb but works every time before anyone has to touch a thing.
If still not working the usual suspect are the water tank valve, flow meter, pump, water path to the heater and hoses. Any of these can cause the machine to not pump the water through.
Which one is most likely to fail? Most would guess the flow meter gets scaled up over time. Or is it most likely the pump itself loses its prime? I’d think scale but what about all of you who has worked on a few of these machines? What have you noticed over time as to what the most common failure are on these models?
