curious about the assault runner elite, worth the hype for curved belts?
The Assault Runner Elite has a unique curved deck design compared to traditional motorized treadmills, as seen in this review footage. A major difference here is that it is manual. You have to keep the belt moving by using your own momentum instead of having a pre-set speed. That could help improve running form while allowing for mimicking varied outdoor terrain. It's appealing to those looking to change up their workout routine. The design features are innovative. There are no speed controls: The console shows distance and pace but it's up to you to control how hard the workout is. It takes some getting used to for beginners: How do you stand on the curved surface? You need to adjust the machine first in order to work out properly. Since there is no large motor system, the machines contain fewer electronics, according to the review. That means the mechanics are simpler, which generally leads to less downtime and longer-lasting maintenance than other standard gym gear. From what I’ve seen, people who like it think it’s got a solid belt system that holds up. The only struggle is getting used to the resistance curve. They don't have issues with the electronics. If you’re curious, you can also see how they fare long-term in terms of any belt tensioning/maintenance issues. It is also good to see whether the console will sync with popular fitness apps, as not all do at this point.
My last gym had one of these, they are called the Woodway Curve. They are very similar to the Assault Runner Elite in terms of how they work. The first couple of weeks, your calves will hate you. But once you get over that hump, you’ll be happy to switch it up from running on a normal treadmill.
And you're right: There's a lot less opportunity to fail from a repair perspective. There is no motor, no incline motor, and no complex control board pushing power to a giant DC motor. It is just slats, a belt, and some bearings. Failures tend to come in the form of cracked individual slats or worn bearings on roller bearings. Both are cheap fixes compared to buying a new motor control board like you would of had to do with your typical treadmill.
So how does this console get power? Do you have to have a motor hooked up to the machine? Does it just draw off of some type of battery? Or is there enough generated by the moving belt that can be used for power?
This little piece of technology has a tiny generator incorporated into its roller assembly which you spin as you run to provide electricity for the display. It even stores setting memory on some models with a coin cell back up battery.
Speaking of displays, they are powered by a small generator built into the roller assembly that your running spins. I am curious to see how long the system will retain a charge between uses and whether the display reverts back to default after sitting idle for a few weeks.
My last gym had one of these, they are called the Woodway Curve. They are very similar to the Assault Runner Elite in terms of how they work. The first couple of weeks, your calves will hate you. But once you get over that hump, you’ll be happy to switch it up from running on a n…
I wouldn’t compare the Assault Runner Elite to the Woodway Curve, as the Assault version costs roughly half as much. However, the Assault Runner Elite is a good compromise between price and features for home use.
Also, I ran on one for about eight months at a CrossFit box before I moved. At some point, the belt slats will begin to squeak. Fixing that is as simple as adding dry silicone lube to the bearings. Do not use WD-40; it attracts dust and makes the problem worse.
It does have a bit of a learning curve. The first time I had someone else try it (at my gym), they almost came flying off the back of it while trying to run sprints. On this machine, you need to let your feet hit below your hips and also lean forward slightly more than if you were just walking or running on a normal treadmill. It’s not that hard once you get the hang of it, but it might take a little practice the first time.
Now, you might be asking: Does it take some adjusting of belt tension over time, as with other treadmills? And does its curved design make the tension self-regulating?
At its price point, it’s solid. A good deal at two thousand dollars for a used one (I got mine off of a marketplace), it's solid for the price point. One user mentioned that after three years of use they've had no maintenance required aside from some bearing lubrication and an occasional wipe-down. There are no belts to calibrate, no electronics to mess with, and no need for any sort of service technician. If you’re looking for equipment that outlasts your desire to go to the gym, this is a good option.
For example, how does the Assault Runner Elite compare to the Trueform treadmill? If you’re not sure which of those machines to get, think about that.
Trueform parts are harder to find, cost more, and feel smoother. Assault Runner Elite has a better dealer network in the US.
Because of the geometry of the curve, the belt will be self-tensioning for the most part. The slats seat on the rollers by gravity. There is no adjustment as there would be on a flat belt. Does it feel loose? Probably not a tension problem but more likely a crack in a slat or wear to the bearing.
