Crockpot won't heat anymore, is it usually the heating band?
i had a cuisinart slow cooker do this and the issue was the temperature control board not the band. The newer slow cookers with electronic settings have more points of failure than the older machines with knobs to control temperature.
interesting, how come they use relays instead of triacs to switch the band on and off with the electronic controls?
actually that raises an interesting question about the use of triacs in these slow cookers. When a triac fails shorted to ground, it will cause the band to continuously run in high mode regardless of the setting selected which would be the cause of a few house fires in operation.
My crockpot bottom cover was not riveted it was screwed on. At least the one i had. Depends on the year and model number to be exact. Dont assume its rivets till you look at the bottom.
definately check the cord first like the other person said. Ive seen a few instances where the cord fails while the band is fine. Its allways the strain relief on the cord.
In over 20 years of repairing small appliances I can count on one hand the number of crockpot bands that failed. All the rest were due to a switch, a cord, or a thermal fuse if it was one of the fancier models with temperature displays. Take the bottom cover off and meter the band before anyone spends time looking for a heating band replacement.
In over 20 years of repairing small appliances I can count on one hand the number of crockpot bands that failed. All the rest were due to a switch, a cord, or a thermal fuse if it was one of the fancier models with temperature displays. Take the bottom cover off and meter the ban…
hard agree. 70% of the time it was the switch or the cord, 20% of the time it was a thermal fuse and 10% of the time the element. The 10% that were the element were all crockpots that were dropped on the floor or placed in standing water.
so you’re telling me my crockpot has a thermal fuse i did not know about? where is it located?
on the crockpots that have a thermal fuse it is located between the heating band leads and the switch. It is usually wrapped in fiberglass to insulate it. The cheaper models do not have this fuse which is sketchy.
how do you know if your crockpot has a thermal fuse without opening it up? is there a way to know from the model number?
Anything with a digital display or programmable settings will have a thermal fuse. The certification requires it. The older models with knobs do not have this fuse although they were made prior to about 2005. Only way to know for sure is to open the crockpot up.
slow cookers are overrated anyway. Instant pot will do the same thing and if something goes wrong its easy to find youtube videos for any part of these machines
on the rivet question, if you have a drill press its a 30 second job per rivet. If you dont have a drill press you can use a handheld one as well just take it slow and use a center punch on the rivet first or it might not want to bit into the crockpot. 1/8 inch is what it took on mine.
on the rivet question, if you have a drill press its a 30 second job per rivet. If you dont have a drill press you can use a handheld one as well just take it slow and use a center punch on the rivet first or it might not want to bit into the crockpot. 1/8 inch is what it took on…
do the new rivets have to be heat rated since its near the heating element? or can you just use regular pop rivets?
actually never thought about this since its a crockpot and not an appliance that is constantly on high mode but thought id ask.
