Cracked open my Craftsman 20V pack, here's what each pin does
Got myself a dead Craftsman 20V to peek inside of before tossing it in the bin. Used a meter to poke around and see what each pad on the BMS did, so dumping this info in case others is wondering what each labeled pads does on one of these tools.
B- and B+ obviously go to the cell. ID is the line the tool use to identify the battery. TH is the thermistor pin for temperature monitor of the battery pack. C1-C4 is taps between each cell group to balance each group of cells.
Nothing too fancy, but its somewhat standard out there in the battery world. The label on the battery pack, however, are not always obvious to those of us who havent opened too many of these packs. The other question that I had was if the ID pin is just a resistor or if there is data on that pin. Unfortunately, too far gone on my battery to test under a load. Also yet to confirm what the value of the thermistor is; didnt want to pull it off the battery. Does anyone knows more about this pin/line specifically? If so, I’d love to hear from you. I’m attempting to try and revive this tool with new cells. Anyone else done this yet?
The ID line on most of these knockoff tier battery packs is just a resistor to ground. Usually a 10k or 22k resistor. The tool read the value of this resistor to decide if your using a genuine tool and battery pack. Since Craftsman tools is mostly just rebadged Stanley and B&D tools under the SBD umbrella, its likely the same with the Craftsman tools as well.
The ID line on most of these knockoff tier battery packs is just a resistor to ground. Usually a 10k or 22k resistor. The tool read the value of this resistor to decide if your using a genuine tool and battery pack. Since Craftsman tools is mostly just rebadged Stanley and B&D to…
Yeah, but have you actualy measured the resistance between the ID and B- pins on a known good battery pack? I’m curious as to whether the value is the same for each Ah rating of battery. It could be used to encode the battery capacity in that way.
I have. On the 2Ah and 4Ah batteries that I have open, the resistance is different on each battery. So, capacity of the battery is encoded in the value of this resistor. Tolerance seems to be rather loose though. I swapped in a 1% resistance value resistor of close to the same resistance as the original and the drill didnt mind too much. I wouldnt trust that every tool would recognize it though. The battery chargers for these tools can be fussy about the chemistry and mAh of the battery that get charged.
The thermistor on every SBD battery that I have cracked open is a 10k NTC that you can safely pull off the battery with a multimeter reading around 10k at room temperature of 25C. The process of reviving the dead battery with new cells is doable but ensure that the chemistry of the cells are the same and the Ah/mAh rating of the battery; otherwise the BMS will trip on each hard pull of the tool. Also ensure that you reset the BMS by giving it a very tiny pulse on the B+ pin after you solder in the new cells. Otherwise it will remain in a protected mode and the tool may read 0 volts despite the cells being in great shape. I lost an afternoon on this tool before I figured it out.
