Can anyone give me some advice about fine dust management?
45
Fellow woodworkers! I got a little question, how serious does fine dust in garages affect us woodworkers? I’m new to woodworking and I needed some advice about it, I’ve read bad stuff about them, and I consider investing in a good vac for it. I got a shop vac but it doesn’t feel good enough for my garage.
Do you have any recommendations, advices, or even information to share with me? Thanks!
That’s a big issue, man! Fine dusts are no joke, they should be properly deal with especially in confined places! There’s plenty of health hazard involving them – get some proper air filter or dust collector in your workplace.
Fine dust seems insignificant at first, but it can harm you and your family in the long-term if handled poorly. Best is to invest into good respirators or filters before any health problems come up.
I have some combinations of ceiling-mounted air filter unit and dust collector in my small shop. Usually, my dust collector is for heavy dusts and the air filter is for small particles. I also wear dust mask adding some extra protection while working.
I know, spending money on these extra gadgets will cost you a little bit. If you are tight on budget, try some DIY filter using a box fan, there’s a way if you really wanted something.
Very hazardous! Do everything in your power to get rid of fine dust in your workplace! Not just bad for health but also fire hazard when builds up near electric outlets!
After hearing myself and my son coughing for weeks due to these little “fine dust”, I never hesitated to buy some air filter for my garage. Plus, I also upgraded to a dust extractor. We never heard a cough since these changes 🤣🤣
Check out cyclone separator – they can be a great accessory for your shop vacs when dealing with fine dusts. Not only they will help your vac’s performance, but also prevents it from clogging fast.
Yeah, man! Masks are the real game changer when it comes to fine dusts – even for the nastiest of all! Plus, it’s a very useful tool when sanding and cutting MDF!
No room for fancy setups – did a DIY box fan with MERV-13 filter – works like a high-end filter!
I had the same setup! Used this setup in ages, decided to upgrade just for the modern approach and a more dedicated air filtration. Nothing, I just missed my old, cheap, cost-effective setup 😄
Thanks for this, man! I never consider ceiling-mounted until you mentioned it. Does this work also on low ceilings? I need more suggestions from you, thanks!
Yes, even for low ceilings, you can still use ceiling-mounted filters. Plus, there are also modern models that are very slick, or you could go with wall-mounted ones if you have a really tight ceiling.
If you’re sharing your space with other items, might as well build a good fine dust proof workplace if you don’t want to constantly clean your place.
What I did was I focused on tool collection improving – this way, I didn’t spend much money at first and I gradually upgraded to a proper filtration after.
Oh, I had this one regret before, I should have known about it earlier – Installing PVC pipe ducting on my tools to a central dust collector. This way is very efficient when collecting fine dust on tools – not cleaning the tools one by one 😄
Plus, I just wanted to add about indoor cutting and sanding – Make a little extra effort about the fine dust they produce, even the best-known dust collector misses a lot when dealing with them, and it’s always a good thing to have a backup fan on your garage.
The only down side to PVC duct is STATIC buildup! I remembered getting zapped every time I work on my garage. Just remember to ground it before installing one. 👍
