Curious if anyone here has cracked one of these Kitchen Mama can openers open for a repair. These tend to be sealed looking units, but not realy all that sealed once you find the right order for opening them up.
The way in is to first remove the battery cover, then use a small screwdriver to pop the front cover off the unit. Under the front cover are two screws that hold the unit together. Once you remove those two screws, the back cover will open. This is common to many unit of this type.
I figured I'd post this in hopes of helping others who may be attempting to repair these. Many people online have given up on these models as being ones that can be opened because they are glued or ultrasonically welded together, when really it's the front trim panel that hide the two screws.
The only question I have is if the front trim panel is fragile to opening with a screwdriver. I've seen clips on many of these gadgets fail and snap off if someone goes too aggressive with a flat head screwdriver. A plastic spudger or even a guitar pick may be a better tool to use that does not risk damaging the unit beyond repair. Has anyone else been in one of these and found out how the front trim panel is clipped on the unit?
