Anyone got tips on opening up a Delonghi La Specialista?
Curious if anyone here has actualy pulled one of these apart for cleaning. There's not a whole lot of information out there on how to get into a La Specialista to clean it (as opposed to a Gaggia or one of the older models from Delonghi). It sounds like its not terribly complicated but you have to see what others has done in the past prior to diving in yourself.
The process requires removing the water tank, the portafilter, the portafilter basket, the accessories, and then removing the outer cover. Beyond that, you will have to take it apart for whatever reason you went into the machine for (if for descaling, group head leaks, etc.). But most people recommend going through a guide or video to show exactly how to do it as some of the clips are not immediate obvious.
Any gotchas with the La Specialista? Does the grinder come apart from the brew side separately? If you’ve done this before on one of these machines, please tell someone who is curious but wants to avoid unnecessary destruction of their machine.
yeah there's a torx under the drip tray on the ones I've seen, T20 iirc. People miss it and then crack the side panel trying to pry it off. Go slow.
Did mine last spring. The grinder assembly is its own module, you can pull it without taking the brew side apart. There's two screws on the burr carrier and a clip for the chute. The brew side is trickier because there's a lot of tubing and the solenoid wiring run across the top.
wait so does the grinder come out from the top or do you have to go in from the side? mine sounds like its grinding gravel and I dont wanna open the whole thing if I just need to clean the burrs
Top access once the upper shell is off. You don't need to fully strip the machine to access it. The hopper comes off first obviously.
plastic tabs are the killer on these. Flex the rear panel outward not up. Learned that the hard way and superglue is now part of my espresso machine
Honestly, worth doing yourself imo unless its still under warranty. Delonghi service told me 180 to descale and do a general checkup on my machine. Took me 40 minutes at home to do it.
Is the pump vibratory or rotary on this model? If its a vibratory pump, then the grommets will eventually harden over time and create a lot of noise when grinding.
definately check to see if there’s a hidden screw behind the steam knob area on the steam wand. There’s a screw there that everyone misses when they first open their machine. I snapped a plastic tab on mine when I didn’t see the screw.
