Hamilton Beach FlexBrew not pumping water, what usually causes it?
See some posts on the FlexBrew units that won’t push water through anymore, hence the topic of discussion about this issue. There are 5 usual suspect for these models before people give up on the machine.
The first is that the reservoir is low on water. After that it could be a clogged water tube (flush it). Beyond that the actual pump could be failing (bad repair). The other two are user error related; the latch on the brew basket could be an issue or the water tank latch doesnt seat proper into the machine; or the holes on the FlexBrew reservoir could be plugged on the carafe or the single serve side of the machine.
What is the most likely of the 5 suspects? I’d say scale in the machine or clogs in the holes since these machines sits with water in them and nobody descales them. But have you done any repairs on a few of these models to see which of the 5 is the most common?
9 times outta 10 its scale. People pour tap water in these things for years and never run vinegar through. The pump struggle so much to push water out since its full of scale.
The latch microswitch on the single serve side is the most common cause of the machine failing to start up. The plastic tab on the switch wear down over time.
wait does the pump run dry if the latch switch is bad or does the machines controller just refuse to allow it to turn on?
I fix small appliances on the side and Ive probably had a dozen FlexBrews. Its scale every single time. Its not the pump that scales, though. Its the check valves and silicone tubing. Descaling only works if you descale through both paths to the carafe and single serve. My trick is to pull the top of the machine and push CLR through the tube to the heater. Does the trick 70% of the time for people with FlexBrew issues. The pump itself rarely dies, but when it does its usually because people ran it dry.
mine started doing this and it was literally the needle hole on the kcup side clogged with grounds. Poked it with a paperclip and it worked again. Felt real stupid
Your gut is right about scale. I’d say its 40% scale 30% latch sensor issue 20% clogged needle 10% pump. Reservoir not seating is part of the latch issue.
vinegar. Just vinegar. Half water, half white vinegar. Run it through twice. Let it sit 15 minutes. Works on every single one ive seen.
Hot take: the pump is undersized. Its a tiny solenoid pump pushing water through 2 different paths. It struggles with even a bit of scale. This is why it dies around the 2 year mark.
does the brand of descaler matter? Ive heard people swear by the hamilton beach brands but the vinegar is the same?
the branded descalers contain citric acid. Vinegar contains acetic acid. Vinegar works just as well but leaves a smell in the machine. Citric acid powder from amazon is around 10 bucks and goes a long time.
