Cracking open a Hamilton Beach FlexBrew, anyone done it?
Curious if anyone here have gone inside an Hamilton Beach FlexBrew units. I'm reading up about how to teardown them and it seem fairly straightforward. Unplug the device and remove the three screw on the bottom of it to gain access to the top portion of the device. The catch on the top portion of the device use plastic clips that you can prise open with a flat screwdriver to gain access to the interior. If done quick the clips can be snapped and the housing will not fit correctly back together like when it first came from the box. These FlexBrews tend to get pulled open to address issues with the pump and heater component. As such, one would think that there would be detailed information regarding their teardown. Yet, there is no information I can find online about them. Has anyone here actualy opened one of these up? Is there any trick to getting into the top portion other than the three screws on the bottom? Does it appear like there are any ribbon cable attached to the top portion of the device?
yeah ive had one apart. The three screws on the bottom are right but theres also a hidden one under the drip tray area on the dual version, not sure which model youre looking at. No ribbon cables tho, just regular wire lead to the heater and pump.
does the click lock setup use the same kind of plastic clips as the keurig classic or is it different? asking cause i snapped two on a keurig last year and im paranoid now
different. They're more like little hook tab around the rim of the unit. Just use a plastic tool to prise the tabs open. Metal screwdriver mark up the plastic.
these things arent worth fixing imo. You can get a new one for like 70 bucks. Spend 2 hour inside one chasing a bad heater and youve already lost money on it.
pulled apart a singleserve flexbrew about 6 months ago. There are three screws on the bottom of the unit, but there are also two on the side that require a guitar pick to access. Pump on one side, heater on the other, control board in front of the button. No ribbon but there is a short wire that goes to the button panel that you can unhook if needed. Scale build up in pump inlet. Once cleared, it works fine again. Tricky part about putting it back together is getting the silicone tubing to properly fit onto the barbed end.
pulled apart a singleserve flexbrew about 6 months ago. There are three screws on the bottom of the unit, but there are also two on the side that require a guitar pick to access. Pump on one side, heater on the other, control board in front of the button. No ribbon but there is a…
guitar pick is smart. Does the heater have a thermal fuse on it that can blow seperately or is it just a one unit assembly?
thermal fuse clipped onto the side of the heater block, can be replaced for ~$3. Heater element is part of the block so if its broken you replace the whole heater assembly.
Reason there's no detailed teardown information for these FlexBrews is because nobody bother with them. They're just tossed in the landfill. Hamilton beach makes these for a certain price point and the repair community just ignores them in favor of the breville products or the higher end stuff. Shame really since the FlexBrew has some of the most servicable component out there.
