Kitchen Mama can opener stops working, what's the usual fix?
Several folks has asked about the Kitchen Mama electric can openers acting up lately. Thought I'd start a thread on the subject since I see it as relatively common. The troubleshooting is fairly short but I'm interested to see if anyone else went deeper into the troubleshooting than just a basics.
Try swapping the 4 AA batteries in the opener. Weak batteries will cause the opener to stall. If that fixes the problem, great. Otherwise, pop the cover on the can opener and inspect the gears for any stripped gear. Most issues is with these component. Try plugging the motor directly into 4 AA batteries to see if it works. If not the motor is broken. Otherwise check the on/off switch to make sure it is functioning proper.
The gear issue on these is common since they are cheap product. Stripped gears are the most common failure after the batteries. Is it possible the motor just gets worn out over time as well?
cracked one open last year for my mother in law. The plastic gear right after the motor pinion gear got chewed up, like someone took a file to it. Replaced with one off a junk unit and it lasted for maybe 6 more months before doing the same thing again.
Wait does the motor actually run on a full 6V from 4 AAs in series, or are they wired in some weird configuration inside the can opener?
4 in series, 6V nominal. Nothing fancy going on inside the battery compartment, its just a dumb little brushed DC motor with a gearbox.
You're missing the most common failure which is the magnetic sensor or whatever it is that tell the can opener that the lid is fully cut. Mine stops in the middle of the cut even though the motor and gears are fine.
The little hall sensor or microswitch (depends on the rev) gets gunked up with food splatter and stops working proper. Clean that with some iso and a qtip and youd be surprised how many come back to life. Everyone goes straight to gears and batteries but theres more going on in there.
The little hall sensor or microswitch (depends on the rev) gets …
this is actually a fair point, the sensor thing tripped mine up once too. Had to replace gearbox but it was the sensor under the housing. Ate up an hour of my life
alot of these issues are just dirty contacts from food splash. No idea why people dont realize it, but its a constant splatter into the seam of the opener. Wipe these down occasionaly and they should last longer
is the hall sensor the one that detects when the lid has completed its rotation or is there a separate encoder for that?
Mine failed differently. The little wheel that grips the rim of the can got worn smooth so it just spun in place. No amount of new batteries or gears will fix this. Roughen that little wheel up or replace it. Simple fix before anyone goes into the gearbox.
