Tefal induction cooker dead, no response from power button?
Seeing as how a few peoples has asked about this same problem I figured I'd share what I've come across.
The first thing to try is simply the power button. Even if it seems like an obvious first question the power button could easy have failed.
If the power button works, then it's likely a fuse issue. There is a fuse in the plug itself. Beyond that though there is another fuse very close to the entrance to the hob's cable itself. You will need to pull the back cover of the hob to access this one. This internal fuse will be the one that tend to fail, as people dont always notice that there is a second fuse within the hob itself. If you have a multimeter you can test the continuity of the fuses to see if they have blown.
Now if the fuse is the one that has blown, is this typically an issue with one of the components within the hob itself? If anyone here has had to replace the internal fuse on one of these Tefals and found that it started working again but then the fuse failed again, would love to hear how this went for you guys?
fuse blowing is almost never just the fuse mate. Its protecting something and 9 times out of 10 thats the IGBT or a bridge rectifier thats shorted. Swap the fuse and itll pop again within seconds of plugging in, ask me how i know lol
Had one of these go on me about a year back. Replaced the internal fuse, ran fine for maybe 3 weeks then died again, ended up being the IGBT like the guy above said. Not worth the hassle tbh, a new induction hob was like 60 quid.
wait so where exactly is the internal fuse located, is it on the main board or its own little holder near the inlet? never opened one of these up before
its in a little ceramic holder usually near where the mains cable comes in, separate from the board. Clips out pretty easy once you have the back off
if you pull the back off check the thermal fuse on the coil too, lot of people miss that one and chase their tail looking at the mains fuse
induction stuff scares me ngl. There's caps in here holding charge long after unplugging, anybody poking around in these things should bleed the caps first, otherwise you're in for a bad time
how do you actually bleed the caps? with a resistor or is there some special tool
a 10k bleeder resistor with insulated leads works fine, just hold it across the cap terminals for a few seconds. Some people use a screwdriver but that will pit the contact and damage the cap if there's any charge left in it.
Tefal's build quality has definitely taken a turn for the worse. My mum had one for 12 years with no issue at all, but the newer model she bought for it failed after just 18 month.
The answer to the OP's question is mainly no. On the very old models that have been through the heating cycle for a decade the fuse is likely the one failing. On models under 5 years old though the fuse is likely the one failing because of some other component within the hob.
Replaced one last summer. Found the fuse to be fine but the membrane switch under the power button was faulty. The flex cable had gotten crusty so the contacts werent holding up. Cleaned with iso and it's working again. So you should test the power button.
Yeah, the membrane switch is a known issue. I've had it happen after someone spilled something on it.
does anyone know if you can get replacement IGBTs for these cheaply? I've seen a couple on ali express for 3 quid each but I'm not too sure if its the right part for a tefal.
