stats remote installer quits instantly with Authorization failed: BAD_REQUEST
7
the system stats remote installer in stats 3.0.21 prints the login link and then quits on the very first token poll. says 5 minutes, lasts about 5 seconds. the 400 from /token is really authorization_pending but the script only checks the error field, so it bails. signing in from inside the app is fine.
Waiting for authorization (5 minutes)...
Authorization failed: BAD_REQUEST. Re-run the script to try again.
Fixed in 3.0.22. The install.sh on the CDN now treats authorization_pending as still waiting, so just run the curl line again.
