Midea mini fridge dial 1 to 6, which number actually runs coldest?
Quick one for anyone run a Midea mini fridge. The internal dial go from 1 to 6, but many argue about which end are which. According to the documentation, 1 is the warmest, and 6 is the coldest. 6 is what you use for the little freezer box on these to make ice or remains frozen.
Many peoples assume that the higher the number on a refrigerator, the warmer the fridge is set to due to other brands out there using that same control. They then crank the fridge to the lowest number to get the most cooling possible, only to discover that the fridge’s freezer compartment are warm. This is a common issue with these refrigerators.
Can someone who owns one of these explain to the audience what the in-between numbers on a Midea mini fridge do? Would 4 be enough for keeping the freezer compartment frozen, or would 5 or 6 be needed? Keeping the fridge at 6 all the time might seem okay for the main compartment but would be detrimental to the freezer box and the main compartment due to the need for the compressor to run 24/7. However, the documentation say nothing about this.
What number have peoples found to work best for their mini-fridge?
4 is my daily on mine, freezer box keeps ice cubes solid and the back wall doesnt ice up the lettuce. Tried 5 for a week in summer and stuff at the back of the fridge started freezing.
wait so does the dial actually control compressor runtime or is there a thermistor in there? like is 6 just a longer duty cycle or does it target an actual lower temp?
its a mechanical thermostat with a capillary tube on most of these little midea units, no thermistor. Higher number = colder temp selected by user = compressor will run for longer periods until fridge reaches that selected temperature.
ran mine on 6 for two years straight in a dorm and didnt waste any energy because of it. People overthink. The little freezer box isnt a freezer it’ll hold ice cream for a couple mins max.
follow up question, if its a capillary tube thermostat would the fridge machine have a dial to control the spring tension on the bellows? would that be the actual mechanism that would control the temperature?
yeah basically. Theres a small bellows filled with gas that connects to the capillary tube, when you turn the dial it moves a cam that presses against a spring that opposes the bellows. When the fridge is colder the gas contracts in the tube which makes the bellows smaller in diameter which allows for the thermostat to allow the spring to overcome the tension on the spring which allows for the compressor to turn on longer to warm up the fridge.
I keep mine on 3 and it's fine. Drinks and lunch are plenty cold. I dont use the freezer box at all, took the little flap off.
the docs are wrong half the time. My haier fridge had 7 as the coldest and it was warm. Support said it was a translation error in the manual lol
the thing people dont mention is that the fridge needs to be in a relatively ambient temp in order for it to work correctly. Mine in a 22 degree ambient temp room runs perfect at 4 but if I move it to the garage where its 30 plus in the summer then 4 is not enough for the fridge to maintain proper cold temps in the fridge compartment.
