Anyone got a clean pinout for the Milwaukee M12 battery?
i had an m12 pack that would not charge, found that the lead from the thermistor had broken where it meets the PCB. Resoldered it and it came back to life. Proves that there's something you can check on these.
yeah ive done it on two packs. Soldered a jst-xh to the pcb tap points, works fine. Just remember the order, very easy to reverse it and pop something.
if I add the jst-xh balance lead like you mentioned, do I need to disconnect it before putting the pack on the milwaukee charger or can I leave it dangling?
the lack of documentation for these M12 packs is somewhat annoying since a few loyal enthusiasts have reverse engineered the M18 to hell and back with github repos and what not but the M12 packs nobody seems to care about since they are relatively cheaper.
this is exactly it. The economics of it, a dead M12 2ah battery is not worth the cells that you can put in it so i will do it just because i dislike discarding things.
speaking of which has anyone heard of a good source for 18650 cells lately? vapourcell has been having some shipping issues.
bring them to the same voltage first. Milwaukee chargers will not compensate for significant difference in voltage between cells. It will throw a fault and refuse to charge. Charge each group to 3.7v with my imax b6 before reassembly.
sorry one more question. When you say charge each group of three to 3.7v before reassembly do you mean the whole group in parallel or each cell individually?
the whole group in parallel will self balance when they are connected in parallel to each other. Just make sure that the individual cells are within 0.05v of each other though otherwise you'll get a nasty spike when you connect them.
OP, your write up is much more thorough than 90% of the content out there on the internet for these packs. I know a lot of it is common knowledge but I'd add that the protection board will lock out if you discharge the cells below ~2.5v per group. To get it going again you have to briefly bypass it with a power supply.
OP, your write up is much more thorough than 90% of the content out there on the internet for these packs. I know a lot of it is common knowledge but I'd add that the protection board will lock out if you discharge the cells below ~2.5v per group. To get it going again you have t…
how briefly and what voltage?
