A few people has mentioned that the Magnifica models are known for overdosing on the grind settings. From what I understand, the usual fix is to adjust the grind to a finer setting (higher number on the dial), lower the strength of the coffee setting and use a single espresso or coffee instead of the double settings. Some say that if the grinder is particularly dirty, that could be contributing to the coffee being dose too heavily as the grounds tend to gum up when old and the burrs do not allow for even extraction of the beans.
I'm not sure what people's experiences have been with any of these fixes though. Does anyone have suggestions as to which is the best fix for the overdosing issue on the Magnifica coffee makers?
