Anyone actually use the delay timer on the Aroma rice cooker?
While flipping through a manual for one of my Aroma cookers I noticed the delay timers goes up to 15 hours out. How many of you uses the delay function for the cook cycles?
I assume that when you hit the delay function you can set how long you want the cycle to be delay and then choose your cooking program. It seems like the cooker will just remain in this state until the delay timer completes and then start the cooking cycle automatically. Would you use this function for something like leaving your rice sit in water for 10 hour+ before cooking?
I'm curious as to how many of you use the delay function and what time ranges you use it for. As stated in the manual hitting the delay button come before choosing cooking program. What happens if you do it in the opposite order?
I use it maybe 3-4x a week, usually in the 6-8 hour range. I will often set it before sleep so that the rice is cook when I wake up. I never use it for more than around 9 hour, since rice sitting in water for that long starts to get sour tasting when I cook it.
15 hour is rather pointless; nobody cooks rice for 15 hours. You'd end up with fermented rice mush. The machine can certainly do it, but it's not something that are recommended.
What happens if you hit the cooking program before the delay function? Does it just start cooking immediately or will it allow the timer to queue up to start the cycle at the select time?
If you hit the cooking program first it just start cooking. The delay function has to be hit before the cooking program for it to take effect.
learned that the hard way coming home to a pot of mush that had been on warm for 11 hour lol
good to know, so it really does ignore the delay if you do it backwards. Why even let you press the button in that order then, seems like bad UI
ive had my aroma for like 6 years and ill be honest i didnt even know it had a delay timer until i read your post. I just hit cook when i wants rice. Seems like alot of extra step for something that takes 25 min anyway
thats the thing tho, the appeal isnt the 25 min cook, its walking in the door and food is already done. But yeah 15hr delay is still dumb
