Cuisinart ice cream maker dead, what's usually the culprit?
Found this writeup on troubleshooting why Cuisinart ice cream makers will not power on. There are only a few thing to check once you have the appliance open. The power switch, motor/drive gear, fuse on the board. Not a huge list of issues but helpful nevertheless.
The fuse within the plug for the unit is one that gets tested on the UK models. You can test the fuse with a multimeter and replace if necessary. This is the first thing that should be checked before opening the unit.
The drive motor and gear are the first of failure for these appliances. The motor work but the gear will fail. Have you opened one of these models? Are the gears plastic or is there a metal gear in these models? Is the power switch a standard switch or one that is proprietary to the appliance?
The gears are all plastic on the ICE-21 and ICE-30 at least, ive been inside a few. The motor itself is fine usually, its the nylon worm gear that strip. The gears can be bought on ebay but usually not worth it to ship the unit in exchange for a gear vs buying a refurbished unit from marketplace for $25
The fuse in the plug is the first thing that anyone with half a brain will check before opening the unit. It takes 30 seconds. Maybe 1 in 10 units will have a blown fuse in the plug but its so easy to check that its impossible not to at the first opportunity.
The gears are all plastic on the ICE-21 and ICE-30 at least, ive been inside a few. The motor itself is fine usually, its the nylon worm gear that strip. The gears can be bought on ebay but usually not worth it to ship the unit in exchange for a gear vs buying a refurbished unit …
If the gear strips can you hear the motor running? How do you differentiate between a failing motor and drive gear?
If it is the drive gear you will hear a faint hum or buzz from the motor, sometimes its a little click click as the motor tries to engage with the stripped gear. A dead motor is silent and may smell of burnt plastic. Put your ear against the unit and switch it on, its pretty obvious.
Honestly I just chuck mine when they die. When you factor in the price of the freezer bowl and buying the unit on sale its around $60. Its not exactly a kitchenaid attachment that you want to save.
The throwaway culture on this thread are depressing. Its a motor a switch a board and a gear. All of which can be repaired or replaced. Its not a sealed iphone.
Is the fuse on the board a glass cartridge fuse or one of those SMD ones that require soldering to the board? Im happy to replace a glass one but soldering to the board scares me.
The switch on mine died approximately two years ago. The contacts inside of the switch were pitted to hell from use. I fixed it by simply replacing the switch with a piece of wire. Once the wire was in place the motor started up fine. I purchased a generic SPST rocker switch from amazon for around $4 and drilled the hole in the switch slightly bigger to allow the wire to pass through the hole. Its been working ever since. So to answer the question posed by the OP the switch is not proprietary as some may claim. Its a standard rocker switch with two spade terminals on the back of the switch.
Plug fuse first, board fuse second, switch third and motor last. Its the order. Anyone tearing open the appliance before checking the fuse in the plug is doing it backwards.
The writeup is basically correct but leaves out the thermal cutoff switch that some of the newer models have inline with the motor windings. If the cutoff switch on the motor fails the motor will exhibit the same symptoms as if the motor itself has fail. Its a matter of bridging the thermal cutoff to test the motor.
The writeup is basically correct but leaves out the thermal cutoff switch that some of the newer models have inline with the motor windings. If the cutoff switch on the motor fails the motor will exhibit the same symptoms as if the motor itself has fail. Its a matter of bridging …
Oh interesting, what is the rating of the thermal cutoff switch? Is it a one time use switch that pops or does it reset on the motor cooling down?
The one I had to remove from the motor on a dead ICE-30 model was a 130C one shot switch. They do not reset. I have seen a resettable one on digikey that I could splice in but I think most do just solder a wire across the switch. Its slightly sketchy in terms of fire safety but the motor is so small its not that big of a deal.
