DeLonghi pulling cold coffee usually the heater fuses?
Been seeing this come up a lot on the DeLonghi machines where the water comes out cold. The first thing I always check are the heater and the thermal fuses on it. Have you all ever done this repair? I'm curious to know if it's almost always the fuses that fail as opposed to the element.
To check the fuses you simply unplug the machine and remove the covers. Under the machine is the heater that you can unscrew to reveal the two fuses. Use a multimeter to test each fuse for continuity. If one of them reads no continuity (as an open circuit) then it's the faulty one and can be replaced. How often do you find that just one of the fuses is bad instead of both? Any reason for this occurrences?
For the replacement fuses I've heard that the original manufacturer ones are rather expensive so maybe using a generic one will work just as well? Also, do you all routinely descale these machines after you replace the fuses to avoid any additional fuse failure?
As someone who purchase these machines relatively regularly I'd think that the heater would last longer than the fuses but thats perhaps the nature of the design of these products.
9 times out of 10 its the fuse. I've done 15 of these and only one where it was the element that failed. The fuse is a sacrificial part of the machine.
scale. It's always scale. These are run on hard water, not descaled and then people get suprised when the fuse blow on them due to the scale on the heater element
The original manufacturer fuse is a waste of money. A generic fuse of the same specs will work just as well. They are a one shot fuses. I get them on ebay for 2 bucks each.
The design of the machine is great but people dont treat it the same as their kettle. These need to be descaled every 30 days. Use soft water if the tap water in your area is hard and the fuses will last you the entirety of the water machine's life.
every month is overkill unless your water is straight limestone
Did one of these on a Magnifica last end of week. Pump fine but no heat. Found one fuse open. Replaced with a generic 192C fuse and it's working great. 3 dollars and 20 minutes of my time. The hardest part was getting the silicone hose off the machine but then I figured it out. I wouldn't let a coffee machine sit idle without regular maintenance.
my comment on the triac got dismissed but if the fuse replacement failed within a week then it's not the fuse it's another component that is making the coffee machine overheat the machine.
